Bruce
Clerestory Roof Trim
Is there an easy way to trim clerestory walls?
At the moment I have to move one roof, trim the top, move the other roof and trim the bottom. There has got to be an easier way.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
7 Replies 7
Open in 3D window and select the wall and only the roof that you wish to be the trimming element; then trim.
...or select relevant wall(s) and roof, THEN open 3D window and perform trims / SEO's
Excellent point! I'm usually always working in a marquee view so your method helps eliminate extraneous 3D elements and would be much faster.
Is this love, that I'm feeling?
Is this the love that I've been searching for?
why SEO's ??? this make the file very heavy
SEO's remain active, whereas "trim to roof" does not update if roof elevation or pitch changes. There are times when "trim to roof" is more appropriate too, though.
