Close Window AC14
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2010-09-15
03:38 AM
‎2023-05-26
02:35 PM
Rubia Torres
‎2010-09-15
03:38 AM
The FILE > CLOSE WINDOW (Ctrl W) shortcut seems to no longer work in AC14.
Now they have revised it to FILE > CLOSE PROJECT and removed the close window option, which I thought was a Windows defult key shortcut anyway.
Does anyone have a solution or work around to this? Does anyone find this as annoying as I do?
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-09-15 03:49 AM
‎2010-09-15
03:49 AM
Try this thread for the answer.
http://archicad-talk.graphisoft.com/viewtopic.php?p=174789&highlight=close#174789
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-09-15 03:54 AM
‎2010-09-15
03:54 AM
Beigemonster wrote:Annoying yes!! Open your WE and reassign the shortcut.
GS in their wisdom thought it correct to change the existing
and then add a NEW command to CLOSE WINDOW.
Close project to me seems pointless, I just changed my shortcut.
Rod Jurich
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-09-15 04:19 AM
‎2010-09-15
04:19 AM
Great, thanks for your help,
I had overlooked that you had to change LIST > CURRENT MENU STRUCTURE to ALL COMMANDS BY THEME to see every available shortcut. I wouldn't have looked at that since AC10 or so.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-09-15 11:39 PM
‎2010-09-15
11:39 PM
Close window (CTRL+W) is under WINDOW>CLOSE WINDOW in the AC14 standard profile.
Is that what you are looking for? I never used Close Window - was it originally assigned to CTRL+SHIFT+W?
AC 6-27 - Intel i9-9900K - RTX3090 - Windows 11 - 64GB RAM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-09-19 07:43 PM
‎2010-09-19
07:43 PM
The close window command affects the active window. If that window is the floor plan view then it will also close the project (or give a warning if it is not saved).
