โ2007-11-02
10:35 PM
โ2023-05-25
06:12 PM
Rubia Torres
โ2007-11-02 11:01 PM
โ2007-11-03 12:41 AM
I f you want to avoid multiple window chaos, there is a setting in Archicad to Always Open new views in a new window, which you can turn OFF!Thomas, would you happen to know where that setting is in AC9?
โ2007-11-03 06:08 PM
Thomas wrote:ALT F4 or click on the X in the upper right corner
In Windows - I have no idea!
โ2007-11-04 01:56 AM
Thomas wrote:CTRL+W works to close the current window.
Djordje wrote:I'm not sure if I've set things up differently, but ALT+F4 closes ArchiCAD on my system.
โ2007-11-05 04:08 PM
โ2007-11-05 09:15 PM
โ2007-11-06 04:56 AM
Tom wrote:
It seems that if I go to another window, it will regenerate if I have aoutrebiuld on, which I usually do. Is there a way to turn each window off without getting to the X, if it is behind the current window.
Thomas wrote:Natively, Windows (XP at least) has no such feature. The TweakUI Powertoy from MS <
On the Mac you can close any window that has it's red close button visible - you just hover the cursor over the button and it turns red, then click, and this works even if the window is in the background and partially obscured by others.
On Windows, again I have no idea.
โ2007-11-06 06:39 AM
Tom wrote:I think you can achieve what you want by working with windows that aren't maximized. Even if you manually stretch the window to take up the most area available, you should be able to minimize the window(s) you're working on and close the rest using the X, without them rebuilding.
Let's say I want to keep the current window open, but close the six windows behind it. It seems that if I go to another window, it will regenerate if I have aoutrebiuld on, which I usually do. Is there a way to turn each window off without getting to the X, if it is behind the current window.
