ā2018-01-30 05:52 PM
ā2018-01-31 09:11 AM
ā2018-01-31 09:54 AM
ā2018-01-31 04:50 PM
Ralph wrote:Hi Ralph,
Apologies if this was answered elsewhere, but is an updated key backward compatible with ARCHICAD versions earlier than 19?
ā2018-01-31 04:52 PM
Barry wrote:Hi Barry,
Does the Archicad 21 update 6000 fix any of the problems with the recalled 5010 update?
ā2018-01-31 06:01 PM
Csaba wrote:Hi Csaba,
The converter is also already available in a standalone format (in english language), downloadable from here: CodeMeter Protection Key Updater.
You can read more about the conversion in our FAQ article.
ā2018-02-01 07:01 PM
ā2018-02-01 08:52 PM
Karl wrote:Cheers,
Finally, what versions of MacOS and Windows is the updated codemeter keyplug and driver compatible with? You stated it will work with older versions of ARCHICAD, but there seems to be an assumption that people are running High Sierra or Windows 10...
ā2018-02-02 09:24 AM
Karl wrote:We have first released CodeMeter keys for ARCHICAD 13. According to the System Requirements, Windows XP/Vista and OS X 10.5/10.6 were the supported Operating Systems for it:
Thanks for the detailed clarification, Csaba!
And for the last question - OS version for which the conversion can be done, and for which it all will still work properly:
Karl wrote:Cheers,
ā2018-02-02 02:04 PM
Csaba wrote:I can now run AC10 with the older (current) setup on OSX10.10.5. (Firmware 2.02, CodeMeter 6.04b.) Will this still work once the key and firmware are upgraded? Or should I leave the firmware and CodeMeter app alone?
Firmware update: if your key has a FW version lower than 2.02, it needs to be upgraded to be compatible with the HID technology. The FW upgrade is being done automatically in our solution (using WIBU's mechanism, the same function that you can reach in the CodeMeter app as well). In the end of this process keys will get Firmware version 2.04. Any keys with a FW version between 1.15 and the newest 4.03 can run ARCHICAD 12-21 without a problem. So this is not a restriction.
CodeMeter Driver version: For the conversion to be successful (and then the key to be usable with the HID communication) the CM Driver needs to be 5.0 or higher. If someone is still on an old ARCHICAD version, then they might be below 5.0 with their CM Driver version. (ARCHICAD 18 and newer should already use 5.0 or higher.) So for some people it's a bit of an extra hassle to uninstall their old CM Driver and install a new one. The new CodeMeter Driver still supports older ARCHICAD versions though. Recently we ran a set of tests with Driver version 6.30d and we even went back to ARCHICAD 13 which - apart from a few cosmetic glitches - was still usable with this new Driver.
