Column Lines
Can column / grid line elements be set to adjust scale with the plans? I have the same issue with the zone tool text settings. If these tools can not accommodate changing plan scales they become obsolete in our work flow which is disappointing.
1 Reply 1
NCornia
Graphisoft Alumni
Graphisoft Alumni
ksk0711,
Yes the grid element markers adjust to scale by default, so do the Zone markers. I wonder, are you changing the scale in the source view or in the Drawing Selection Settings? These two scale settings behave differently. When you change the scale of the source view then the annotation will scale up or down. When you change the scale of a drawing in the drawing Selection Settings the annotation and the model elements are resized together. I hope this helps.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
