Column height not reaching the linked top story
Abdullah Chaus
I have a wall and a column at the end. But somehow, the column height does not reach the top linked story even though the wall does. What am I doing wrong?
AbdullahChaus_1-1729422304325.png  Column settings
AbdullahChaus_2-1729422349356.png  Wall settings
The story height is 3 meters btw.
Operating system used: Windows Windows 11 Home, AMD Ryzen 5 5600H with Radeon | 3.30 GHz | 24.0 GB RAM
David Maudlin
Abdullah Chaus:
In the Column Settings dialog box, look at the Top Link offset under Positioning, it looks like it is not set to zero.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
Abdullah Chaus:
Thanks David. That was it!
Setup info provided by author
