Column
Hey everybody, i have a question, is there any way to make a column like this in archicad, using JUST the column tool?
3 REPLIES 3
Using just the column Tool??? Not that I would know of.
Hi Edgar, this example was already posted.
I just added a parameter for square section. Use 3D hotspots.
It is possible. Use 3 Columns.
Cut the one that is vertically in the middle by two parallel Roofs as shown on the below picture.
You see on the left how they looked before cutting, the one of the right after cutting.
