Command similar to Autocad Tracking?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2012-09-25 04:37 PM
Thank you to anyone who may have some insight.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-09-25 05:59 PM
1. Let's say you want to move a dining table to be 5'-0" to the right of a wall corner.
2. Grab the dining table by a corner, then enter the 'Drag' command (or choose 'Drag' from the menus, or just drag it using the pet palette).
3. Drag the dining table to the wall corner, and just hover it at the corner.
4. Type X5-0+ which will move the table in the x direction 5'-0" positive (to the right). To move it to the left you would type X5-0- (negative direction).
You can combine this with the Y coordinates too, so you'd enter X5-0+ and then Y5-0+ to move it 5 feet over and 5 feet up... make any sense?
This thread discusses a few other ways to do this.
Mac OSX 10.14.5 on MacBook Pro 2.3GHz Intel i7, 16GB Ram, NVIDIA GeForce GT 750M 2GB VRAM, 500GB SSD
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-09-27 03:20 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-09-28 08:29 PM
Do you know if it's possible to do something similar with the dimension tool? When I make a string of new dimensions I want them to be 1' away from another string of dimensions (on a 1/4" scale architectural drawing). I drag my string after I've made it and I want to tell it to be 1' away from the next string. Now I make the dim string, draw a reference line 1' away, and then go back and drag my dim string to the reference line. That is too many steps!
Again, any help appreciated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-09-29 01:05 PM
After placing the dimension points and double-clicking to get the Hammer icon to place the dimension string, move the cursor to the existing dimension line you want to measure from (the cursor will change to the mercedes icon when you are on this existing dimension line), then use the techniques mentioned earlier in this thread to move the cursor to the desired location, then hit the Return key to place the dimension string.
David
www.davidmaudlin.com
Digital Architecture
AC28 USA ⢠Mac mini M4 Pro OSX15 | 64 gb ram ⢠MacBook Pro M3 Pro | 36 gb ram OSX14
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-09-29 05:20 PM
If you haven't already figured it out, you can select only a tick-mark and delete it, and then AC will clean it up for you. For example, if you have a 4' and a 6' dimension (10' overall) then you can delete the tick-mark and it will automatically clean up as a 10' dimension. Maybe obvious but some people will work a long time without knowing this trick.
Conversely, if you select an entire string and then command-click on a new point, it will add a tick-mark in between, turning your 10' string into 4' and 6'.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-10-01 09:26 PM
David wrote:Thank you. That is helpful. I will look into doing that!
JenSaysLessIsMore:
David
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
jbArch wrote:Yes. I love this feature!
Also I often will simply 'drag a copy' of my first dimension string, then edit it as needed by adding or subtracting points to the string.
Thank you!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-10-01 09:31 PM
JenSaysLessIsMore wrote:Ok...I think I got it? Maybe?David wrote:Thank you. That is helpful. I will look into doing that!
JenSaysLessIsMore:
David
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2012-10-02 02:16 PM
JenSaysLessIsMore wrote:Yup. Thanks.JenSaysLessIsMore wrote:Ok...I think I got it? Maybe?David wrote:Thank you. That is helpful. I will look into doing that!
JenSaysLessIsMore:
Davidš
David
