Command similar to Autocad Tracking?
Is there a command in ArchiCad similar to the tracking command in AutoCad? I liked to be able to move something and tell it how far away to be from another element all in one command. (Versus moving an element to one spot and then moving it again to get it in its final spot.) It's hard to explain unless you've used the AutoCad tracking command!
Thank you to anyone who may have some insight.
10 Replies 10
Stress Co_
David wrote:
Thank you. That is helpful. I will look into doing that!
Ok...I think I got it? Maybe? 🙂
Yup. Thanks.
Maybe not?
It should update your earlier posts too?
As David says.. use the profile button.
Marc Corney, Architect
Red Canoe Architecture, P. A.
