2018-08-08
03:57 PM
2023-05-24
08:20 AM
Rubia Torres
Solved! Go to Solution.
2018-08-08 04:49 PM
2018-08-08 04:03 PM
2018-08-08 04:31 PM
2018-08-08 04:49 PM
2018-08-08 05:09 PM
2018-08-08 05:31 PM
Andrew wrote:Anything you want to add to the face of the Plasterboard, and you want it to move when you resize the plasterboard thickness modifier, you'll need to add both vertical edges of the adjacent Fill to that modifier - so they move/offset as well.
Just a question moving forward - if I wanted to make a villaboard + tiles modifier/materials. I would just stack them above the plasterboard/skirting? I think this method will work, just potentially messy.
2018-08-08 05:51 PM
2018-08-08 05:57 PM
2018-08-08 06:03 PM
Andrew wrote:Check your "Element Transfer Settings" (Edit / Element Settings).
Yep, makes perfect sense.
Sorry just another somewhat relevant question. I just added the wall with the settings to display plasterboard + skirting on one side, and villa/tiles on the other as a newly defined favorite.
It inserts the default settings when I double click the favourite and place it in the project.
Eyedropping an existing one works, and editing the favourite shows the settings are correct.
Is this a bug/intended? I was aiming to focus on using favourites for presets, but will go back to using a module if needed.
2018-08-08 06:10 PM
