Rene Pahlavan
Complex Profile Wall corner connection issues
I created a complex profile foundation wall that is two ICF bricks high (ie. 3 feet) - these two walls are joining up fine in plan, but the 3D has these overlaps that I cannot get rid of. The walls are exactly the same in terms of settings and positioning. Some screenshots attached. I seem to have tried everything to get rid of it (including restarting and repairing the file). Anyone any ideas what else I could try?
Screenshots for illustrations below:
works fine in plan
settings are exactly the same
AC28 (Apple Silicon)
macOS Tahoe 26.5
MBP M3 Max (16-inch 2023)
1 Solution
Rene Pahlavan
OK - now figured out how to fix this problem too. Eye-droppered one wall and injected to the other. Even though the walls were all the same, must've been a different wall setting somewhere.
Hope this is helpful to others that may experience this.
macOS Tahoe 26.5
Go to post
7 Replies 7
Guru
They are not overlapping with some wall above are they?
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
Rene Pahlavan
No overlapping walls.
macOS Tahoe 26.5
Rene Pahlavan
Ok - looks like I figured out the problem. Working in a hotlink module - somehow there were multiple copies of the complex profile with the same names. Identical in every way, but obviously not getting along. I went through and "delete and replace" the copies and replaced with the one I need to keep.
However, now some of the corners won't intersect properly, while others do. Screenshots attached.
 bad corner
 good corner
macOS Tahoe 26.5
Rene Pahlavan
macOS Tahoe 26.5
Guru
Slightly different z values?
Rene Pahlavan
No they were the same. Turns out I had two complex profiles with the same name in the mod file - deleting and replacing one solved the problem, along with eyedropping and injecting all settings into all the walls. Solved. Thanks Lingwisyer for your help!
macOS Tahoe 26.5
Guru
Ah, the attribute management nightmare...
