Complex slab
I am confronted with modelling a concrete slab where the top surface is of a given slope and the bottom (soffit) is a different slope, thus creating a slab of variable thickness
Obviously, the slab tool does not work; the mesh tool would be useful for the top slab only.
My present solution is using two roof slabs, one for the top surface and one (different slope ) for the bottom, and joining them using "solid elements", a rather cumbersome solution.
Has anybody done this before in a different and easier manner?
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
Link
Depends on the shape of the slab (in plan), You could consider using a complex profile and a wall. Otherwise I think you're on the money.
Link.
Dwight
Like this - a wall with defined complex profile
Dwight Atkinson
