DanyThailand
Composit wall not wrapping correctly in 3 D view
In 3
D view, the composite wall is not displaying correctly, i use wrap on column option, it show properly on 2 d but not on 3 d, must be 2 layer on column but it show one thick layer instead of 2 ( render + tile.
13 Replies 13
Hi @DanyThailand,
Can tell us more about your case if it's solved or still?
If solved how you could?
If not, can you attach screenshot for these walls while they're selected?
AC 29 INT 4006/WIN 11
DanyThailand
not solved, independant wall or intersected, the profile wont continue on column ( wrap method ). Here is the screenshot
Ok, after I could reproduce that case,
I can find the problem in rectangular wrapped columns appearance in 3D View when placed inside composite walls despite 2D floorplan appearance is perfect.
  • When physically based rendering is ON.
  • When physically based rendering is OFF.
  • Even exist in Ver. 25.
  • I noticed the problem is in the column veneer's surface material which is applied to the top end surface despite inactive veneer as in these two case
the 1st has Stone BM and the 2nd has Generic - external cladding.
  • I can't approve it's a bug or a trick in Archicad which i should know,
but for now, as illustrated above you should use a complex profile column with the composite wall for a better 3D appearance.
DanyThailand
For sure, it should be considered as a bug, what else ? Since a material is classified as finishing on composite, it should wrap around the core of the column, now, it work only with one finishing material, more than one ( for exemple plaster + tile ) , it doesnt work in 3 D. Doesn't make any sense to have composite, column wrapping method but still have to make a profile for the column.
I think this is actually as intended.
It does not say explicitly in the HELP reference that the finish/other skins will wrap in 3D.
It does say the thickness of the column will be increased and that the external surface material of the wall will be carried around the column.
Which is what happens.
https://help.graphisoft.com/AC/27/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC27_Help%2F040_Eleme...
Generally you will not be looking at the top of the column in 3D - it would usually be covered by a slab or a roof.
Only if you select the elements in isolation or add a cutting plane, would you see them as you have shown.
A section through one of those columns will also be a problem as it will show the original composite wall in the middle of the column.
Column will have correct width but will not show the wrapped skins.
So it would be nice to have the skins wrap in 3D as well.
Maybe make a wish for this feature in the 'Wishes' forum and reference this post for explanation.
mthd
Hi @DanyThailand, I think all you really need to do for now, to make it look right in 3D, is to ensure that your external wall skin matches the external skin of your column. You might also need to use PBC or “Priority Based Connections” to tweak it further if it needs it ?
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
DanyThailand
i dont need my wall skin to match the column skin, i need the opposite. I have already tried material priority. It's a bug.
DanyThailand
yes, using cutting floor plan will be  a problem, anyway, wrap is wrap, anything classified as finishing in composite wall should be wrapped to column or call this method " wrap somehow, some, sometime, about, approximative " . Why it only work when there's only 1 skin, doesnt work with more than 1 skin, what is the logic, the mood of the programmer ?
It can wrap more than one skin (in plan), so long as the wall composite skins are not set as 'core'.
In 3D only the surface material will be wrapped, but the size of the column will increase by the skins being wrapped.
