‎2006-01-18 11:03 PM
‎2006-01-20 12:11 AM
‎2006-01-20 12:17 AM
sirduncan wrote:refer: louis armstrong . . .
but my goal is to leave the dark ages behind and move into the world of BIM where you just model the whole thing in 3D and then output because it is all put together correctly.
‎2006-01-20 12:23 AM
‎2006-01-20 02:57 AM
‎2006-01-20 03:35 AM
‎2006-01-20 06:36 AM
Gerald wrote:i was just about to suggest Cadimage. Is it Wall Builder that you are referring to? I just happen to be working on a basement detail, but i didn't know you could 'slide' composite layers, as you suggest. Do you experience with it?
sirduncan,
You can acheive this dropping down of the veneer with CadImage Accessory add-on. This has always been a wish for me too and I don't think this should have to be an Add-on but for now it is.
‎2006-01-20 04:44 PM
‎2006-01-23 04:15 AM
‎2006-01-23 07:45 AM
Erika wrote:Another option could be a GDL object.
Two other options:
1. The wall accessories free with ArchiCAD to get the brick veneer ; it can be inputted to drop down as far as you want.
2. Have the walls on different layers and layer intersection numbers
