TDabney
Composite Wall corner cleanup
Hi!
I've created 2 pretty simple composite wall types.
1. represents an 8" core ICF block wall
2. represents a 10" core ICF block wall
The foam wall thickness of the block is the same for both types.
When I have a corner situation where a 10" wall meets an 8" wall, there is a short section at the exterior corner that doesn't clean up correctly. See the attached image below for reference... What can I do differently to get it to clean up correctly?
Thank you!
Tom
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
3 Replies 3
NCornia
Hi Tom,
Please select the wall; right-click and choose Edit Selected Composite (Also in Options > Element Attributes > Composites). Turn on or change the pen for the Skin End Line of the given skin.
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
TDabney
Thank you Nicholas. That worked great! For whatever reason, I'd never run into that before in my use of composites. Always learning!
Tom
macOS 12.7
Apple M1 Max
ArchiCAD 26/27
should this clean up method work if the walls were drawn on center?
