‎2023-04-18 10:05 AM
Any idea why these two don't connect properly? Concrete Building Material set to 900, CMU to 800. Saved as cores in composite walls. All else is less of a priority in BM and saved as "other" & "finish". Walls on the same layer.
The finishes should connect, but the concrete structure overrides them.
‎2023-04-18 10:53 AM - edited ‎2023-04-18 10:57 AM
Are you talking about this?
‎2023-04-18 02:48 PM
Yes, seems to be exactly the case. Solution?
‎2023-04-18 03:52 PM - edited ‎2023-04-18 03:53 PM
solution??
The blue line at the bottom is only sent down to the end.
‎2023-04-18 04:09 PM
Oh, OK sorry, I spoke too soon. Indeed not the case! The walls are connected and the finishes should show outside but for whatever reason the concrete overrides them in my case.
‎2023-04-18 04:25 PM
The reason I'm shortening the text and sending only images is because I'm not an English-speaking person, so I'm afraid I'll be wrong with the explanation.
Are you saying you can't do that now?
