MrSoleil
Composite Walls with finishes not connecting properly
Any idea why these two don't connect properly? Concrete Building Material set to 900, CMU to 800. Saved as cores in composite walls. All else is less of a priority in BM and saved as "other" & "finish". Walls on the same layer.
The finishes should connect, but the concrete structure overrides them.
5 Replies 5
LeeJaeYoung
Are you talking about this?
AC27 on window 11
MrSoleil
Yes, seems to be exactly the case. Solution?
LeeJaeYoung
solution??
The blue line at the bottom is only sent down to the end.
AC27 on window 11
MrSoleil
Oh, OK sorry, I spoke too soon. Indeed not the case! The walls are connected and the finishes should show outside but for whatever reason the concrete overrides them in my case.
LeeJaeYoung
The reason I'm shortening the text and sending only images is because I'm not an English-speaking person, so I'm afraid I'll be wrong with the explanation.
Are you saying you can't do that now?
AC27 on window 11
