Composite not intersecting properly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-10-24
11:35 PM
‎2023-05-09
02:20 PM
Rubia Torres
Hi, I'm having an issue with a composite floor slab interacting with a footing. The footing consists of a simple slab with a "Structural Concrete" material. The floor slab is a composite with a 4" "non-structural concrete" material and a gravel fill.
The footing is on a layer with an intersection group number of 1; the slab is on a layer with an intersection group number of 1. (note, no change if I place them both on the same layer)
The structural concrete has an intersection priority of 760, the non-structural concrete is 350, the gravel is 5.
All elements have renovation status set to "new". They're on the same storey. If I change the composite slab into a single slab, it also doesn't intersect properly.
Anything else I need to check?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-25 12:55 AM
You will need to apply a SEO to clean up the connection.
This INTERSECTION GUIDE may help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-25 01:03 AM
Thanks. That's a handy little chart.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-10-25 08:34 AM
If you model the footing as a beam, it will intersect automatically.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
