Display malfunction of Graphisoft ID dashboard
Learn more
Jere
Composite not intersecting properly
Hi, I'm having an issue with a composite floor slab interacting with a footing. The footing consists of a simple slab with a "Structural Concrete" material. The floor slab is a composite with a 4" "non-structural concrete" material and a gravel fill.
The footing is on a layer with an intersection group number of 1; the slab is on a layer with an intersection group number of 1. (note, no change if I place them both on the same layer)
The structural concrete has an intersection priority of 760, the non-structural concrete is 350, the gravel is 5.
All elements have renovation status set to "new". They're on the same storey. If I change the composite slab into a single slab, it also doesn't intersect properly.
Anything else I need to check?
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
1 Solution
DGSketcher
Legend
You will need to apply a SEO to clean up the connection.
This INTERSECTION GUIDE may help.
Go to post
3 Replies 3
DGSketcher
Legend
Jere
Thanks. That's a handy little chart.
Erwin Edel
If you model the footing as a beam, it will intersect automatically.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
