2008-09-09
02:57 PM
2023-05-23
03:08 PM
Rubia Torres
2008-09-09 11:05 PM
Tom wrote:tom
Don't want any fills to show up, just the lines.
2008-09-09 11:09 PM
Peter wrote:... unless your model view option is set
The way you had set it up before should work properly. If the fills are different the lines should display. Strange bug!
2008-09-09 11:50 PM
2008-09-10 12:34 AM
2008-09-10 03:22 PM
2008-09-10 06:44 PM
2008-09-11 10:31 PM
2008-09-12 12:17 AM
Tom wrote:doh! of course. because every element is given the same cut fill settings they heal. well figured out.
The answer lies in the section mark settings. Under Model Display, Cut Elements....if the "Uniform Pen for Cut Elements" box is checked, you only see the outline of the wall.
