zgeorgievg
Composite wall T junction display problem
I am having problems with these composite walls. Tried everything I could find online and still can not solve my problem. Does anyone have a suggestion?
Any help would be appreciated. Thanks.
AC25 int, Win10 64bit
If you cannot make it work, try to use a Column with a custom profile placed at the intersection. See this thread for details:
http://archicad-talk.graphisoft.com/viewtopic.php?p=234454
Have you tried looking at the the reference lines of the walls? Ive found that this can influence the way the walls intersect.
maybe change the reference line for the middle wall to the centre.
