Composite wall problems
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2014-06-05
04:09 AM
- last edited on
2023-05-24
08:59 AM
by
Rubia Torres
2014-06-05
04:09 AM
Doesn't this defeat the purpose of having the clever priority based junctions and other 'time-saving' features? It is much easier to add the insulation as a 2D fill than to have to remove it where it overlaps.
Or does the AC process now expect us to create complex profiles of walls including top and bottom plates and filling between them with insulation? Does not solve the stud problem, of course, because if these are also shown, insulation still overlaps them!
I really want to know how, and if, the current Archicad approach, whilst theoretically better, actually makes our drafting more tedious when we move beyond simple walls, floors and roofs.
Cornelis (Kees) Wegman
cornelis wegman architects
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-05-23 09:03 PM
2015-05-23
09:03 PM
I also use complex profiles a great deal and there are still limitations. When detailing timber framed walls I create complex profiles with insulation in the timber frame zone, then add the timber framing as a separate layer using a higher piriority material that cuts the insulation.
I haven't tested this using Ecodesigner so I am not sure if the combination is calculated correctly for the timber frame bridging the insulation.
Tim Ball
AC26, iMac
User since V5
AC26, iMac
User since V5
