Composite wall refenrence line
Hello everyone,
Pending my training coming next month, I am going through the tutorial and wonder how to get the reference line to attach to edge of stud rather that face or center of composite walls.. I see it can be done on existing walls...
Also, what's the quickest way to measure the length of a wall? can't find a measure command..
Finally, is R1 1410 the latest patch (USA)?
Thank You
4 Replies 4
David Pacifico
Same way, In the upper right corner of the wall settings dialog box you can specify how much you want it offset.
I still prefer to place the user origin at one end of what I want to measure, then move the cursor to the other end, then read the delta R value in the coordinate box. You could also use the Window/Floating Pallets/ Element Information.
Yes
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
Thank You David.. I really have to work on customizing shortcuts as am the keyboard type..
David Pacifico
Shift-ALT will relocate your User Origin when your cursor is on a node. You could also set a keyboard shortcut to toggle the element info box on and off. Options/Customize/Keyboard Shortcuts under Menu Commands.
For a list of keyboard shortcuts for Actions and Tools check my last newsletter:
http://www.parch.com/news/news75.html
David Pacifico, RA
Thanks.. will take a look...
