Composites wall
Hi there im having a problem when im trying to create an composite wall.
I can change the edit skin and structures but when i click on the Edit Selected Item arrow it drop down and popup again i cannot change or edit the width of the walls as i wanted. Can anyone help me ? Thanks alot
lovetrain
These r 2 screen shoots i tooks b4 i click on the Edit Selected Item and after
this is the 2nd screen shoot
You need to change the dimensions of each skin/fill, this is located in the edit selected items, below where you select fills and line types etc.. On the Mac I have found that I need to click on the view of the composite for the total thickness to update properly.
HTH
Jeffrey
