Marszel91
Concrete block wall
Hi everyone!
I am struggling with some problems with my concrete block wall.
1. I made a symbol fill which I have applied to the building material and set as a fit to skin. It follows the orientation, but the fill doesn't start with the beginning of the wall. Looks like it refers to a random point instead of the beginning of the wall.
2. Is it possible to create a building material that presents 2 different fills in plan and in section - exactly how it would be in reality, following real size of the concrete block or brick? Pasting some screenshots, I hope it explains it a bit better.
3 Replies 3
Ricardo Lopez
Hi @Marszel91
A building material cannot have two cut fillings at the same time, but there is an alternative solution that might work for you:
1. Create a symbol cut fill for horizontal (plan) with the Fill Orientation as Fit to Skin.
2. Create a symbol cut fill for vertical (section) views. Do not draw vertical lines.
3. Create a new Graphic Override Rule and Graphic Override Combination with a special criteria for that CMU building material, so this last new "vertical" fill applies for cuts.
4. Apply that Graphic Override Combination to section views.
Ricardo López, M. Arch.
Lingwisyer
Guru
Do note though that GOs will override the entire element, so if you are using a Composite, it will override all layers.
Erwin Edel
As far as I know you can't allign cut fills, so the block pattern is going to end up being related to the origin of the view, rather than showing a realistic section. You are better off patching your section up with a 2D object, in my opinion.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
