2026-01-13
05:57 AM
- last edited on
2026-01-14
10:05 PM
by
When I try and drag, this time just a fill, the drag will only allow multiples of 2000mm. I can type the number into tracker but i just want to drag to a point without having to measure it first. It was working fine but after a reboot is still not playing ball.
Operating system used: Windows 11 25H2
Solved! Go to Solution.
2026-01-13 07:39 AM - edited 2026-01-13 07:42 AM
It looks like your Grid Snap is turned on by mistake. Alt+S toggles it.
If you don't use this often, it's advisable to remove this keyboard shortcut from your work environment or, better still, assign it to something else.
