Continuous stair railing on slab
People
Let's say I create a stair from within Stairmaker and add some railing.
This stair ends to a slab that in turn leads to the main entrance door that is at the height of 1.5 m.
How can I add to the slab the same railing that I have on the stair?
The railings that Stairmaker uses are not part of the AC Library.
Thank you in advance
13 REPLIES 13
chris_pap wrote:
People
You could include a landing in your stair that would have the same railing.
Making your own railings is so easy with ArchiCAD that I never use the ones generated by Stairmaker anyway. Learning to do this is fun and you will never have to worry about the kind of problem you listed above.
What does the stair railing you want look like? I will send you an example of how to make your own if you like.
It's nothing in particular.
I just wish that the railings Stairmaker uses were GDL objects so that I could use them on the landing just like the other types of railings the Library contains.
me too.
Could you plese show me the way you create your own railings?
It sounds interesting.
At the risk of posting redundant informaion (again--sorry)
see if this link gives you as much info as you need to make the custom handrails.
http://archicad-talk.graphisoft.com/viewtopic.php?t=3350&highlight=curved+handrail
If not I would be glad to show you now I do it. Be sure to click on the picture below to see it in detail.
Stephen Dolbee
I thought they were. In Object Library 9/Concrete/Stairmaker Handrails.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
No,they are not...
Unless you are not looking through the Library Manager like I am
You know... one of the things I love about ArchiCAD is that no matter how long you've been using it there are some things you just never think of! I've been using ArchiCAD since 1987, when it first came to the US; I think profiler has been around since TeamWork (5.5) and I use it for many things but I've never used it for a railing. I certainly will in the future.
I have, however used TrussMaker for railings and I can see that with a combination of profiler and TrussMaker you could do some amazing railings.
Djordje
chris_pap wrote:
No,they are not...
In International version, all the railings, StairMaker or not, are in 1.4 Building structures\Fences and railings 9
Of course, the defaults do not match the StairMaker defaults ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
