2007-02-01
12:19 PM
2023-05-25
06:15 PM
Rubia Torres
2007-02-02 12:00 AM
2007-02-02 08:06 AM
2007-02-02 08:28 AM
Keith wrote:
I suspect I'm missing something simple, but am finding when I insert a window in a wall, I have a choice of :
a) setting the wall contours to 0 (none), so that I don't see the outline of the wall below the sill, but then I don't get the end lines of wall at the jambs., or
b) setting the wall contours to 1, so that now I see the end lines of the wall at the jambs, but I also get the outline of the wall below the sill.
The wall contour line setting under 'Floor Plan Representation' seems to work indepently of the first parameter, but doesn't affect the wall ends at the jambs.
How can I get both the wall ends and no contour lines below the cill?
(Sorry if this question has been asked before, but I do find the Search facility less than useful)
KEITH
Archicad 10 on MAC OSX
2007-02-02 10:08 AM
2007-02-02 05:16 PM
Keith wrote:I assume your using "Grab" to get your screen shot? Open the tiff in "Preview". Choose File> Save As .... Pick a format.
I've tried to attach a screen shot in the past. The Mac makes a TIFF file, but ArchiCAD-Talk won't accept a TIFF. How do you get over that? Also I'd welcome a brief explanation of how you do the Quote thing.
2007-02-02 05:52 PM
Stress wrote:As you can see, got the quotes sorted.
To use "quote" ..... click the "quote button, at the far right side of the post. (on the posted: date line)
2007-02-02 06:32 PM
2007-02-02 11:22 PM
2007-02-04 06:16 AM
Link wrote:not directly from the UI - or if you can i've never found it!
... but can't you change the format it captures to? I am sure I saw it somewhere in the OS.![]()
