Contours of intersections in Elevations
Hi people
Does anyone have any idea how to eliminate the contours that appear in Elevations?
Even in a simple two story model with slabs,walls and beams the intersection of these elements appear in the elevation.
Thank you in advance
Stephen Dolbee
Make sure the materials are the same for your walls, beams, and slab edges.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Also Play with the Intersection Properties of each Layer that these objects are on.
Remember to Update any Views after finding the Intersection numbers that work....
Jay
there's a simple discission of this problem
First, you need to activate special menu. For windows:
start - run - regedit
In this window you need to follow the next path:
hkey_current_user\software\graphisoft\archicad\"your version of AC"
Than you find "special menu" in the right side and type 1 there
Now open Archicad and figure out the new "special" menu in the menu bar. Here you have to enable "show penetration lines" and relax
Now you are ready to build your elevation
