Convert Educational to Commercial
We have some models created in the educational version of ArchiCAD.
Is it possible to convert these to the commercial version?
I've searched a bit, but find only stuff rom 10 years ago.
Is it possible?
Also, if it's not possible, I assume there is a workaround to export to ICF or something and then import, but what's the best solution?
6 Replies 6
Once a file is educational it will remain educational.
I think this is to stop firms using the free educational software to produce commercial files.
Saving as IFC may work but I can't say for sure.
Give it a try and see - unless the educational version does not allow you to save IFC files.
That may be the case to again stop commercial firms from using the educational software.
Eduardo Rolon
A more recent discussion (2015) that started with AC12 EDU.
Still relevant.
http://archicad-talk.graphisoft.com/viewtopic.php?t=34990&postdays=0&postorder=asc&&start=0
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Why does ArchiCAD ask me "if I want to convert from Edu to Commercial file when I start it up?"
Eduardo Rolon
Does not make sense since this is the message you should get.
AC29 US/INT -> AC08
Here's the message
Eduardo Rolon
Looks like you found a Bug since I have never seen that message.
What happens when you click Convert?
AC29 US/INT -> AC08
