Copy and Paste in ArchiCAD 27
Martin Jules
Mentor
Whatever the way I used, I couldn't paste the following drawing I copied from ArchiCAD 27 to ArchiCAD 27 within the same file :
I would appreciate your insigths on that.
Martin Luther Jules
AC 10-28 (Full)
Asus | 64 GB RAM | Windows 11
15 REPLIES 15
Nothing has changed that I am aware of.
Select, copy, move somewhere else, paste.
Does this apply to anything you copy & paste (i.e. just a single line).
Or only what you show in your image.
If just what is in your image, then you will need to investigate what is in there that is causing the problem.
Try selecting less elements.
Martin Jules
Mentor
It's frozen anytime, and I was surprised about that.
Martin Luther Jules
AC 10-28 (Full)
I am surprised as well.
So you can't copy & paste anything in 27?
Have you tried key board shortcuts as well as right click context menu or the EDIT menu?
It works properly for small and medium projects, but not for large ones.
Martin Luther Jules
AC 10-28 (Full)
Botonis
Mentor
Are those Archicad elements?
As a workaround use the marquee and save as module, import back and emded.
Although copy should work but maybe this is a hardware matter... Or a faulty library element.
Try also a repair.
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
How many elements are we talking about? You can check it in the Edit Selection Set Dialog (CTRL+SHIFT+T).
This is another project, which is smaller than that I had shown previously, and still have the same issue.
Martin Luther Jules
AC 10-28 (Full)
That is less than 3,000 elements, which Archicad should be able to handle easily.
I recommend that you contact your local reseller with this issue and ask for their help in resolving it.
The screenshot regarding the elements is also enclosed.
Martin Luther Jules
AC 10-28 (Full)
