2020-05-13
12:08 PM
2023-05-09
04:16 PM
Rubia Torres
Solved! Go to Solution.
2020-05-13 12:13 PM
2020-05-13 12:13 PM
2020-05-13 12:44 PM
2020-05-13 01:58 PM
Barry wrote:I was a bit too fast on my conclusion. When copy pasting walls they show perfectly fine in 2D but red in 3D. The renovation filter is on "Show all elements" and the texture is a default ARCHICAD one "Paint - Titanium White". Do you have any idea what could cause this issue?
Check that there is nor Graphic Override or Renovation Filter active that is overriding the pen colours.
2020-05-14 03:36 AM
2020-05-14 11:43 AM
Barry wrote:I think it must have been something with the classification system error that I had before.
Could it be a Graphic Override?
If all surfaces of the wall are changing then I would suspect a GO.
Is it just that one material changing or are all materials showing red?
Is it just walls or slabs and roofs with the same material as well?
