AGaspar
Copying Walls between stories problem.
I´m having a problem copying walls between levels. When I copy and paste a wall on to new level the paste walls becomes 2d (Lines and Fills).
I can copy past on the same level with no problems or in between diferente Archicad projects, but not in the same file.
This is happening only on custom composite walls I created personally. If I use a composite wall that came with Archicad it works fine.
I´m Working on Archicad 25.
1 Solution
AGaspar
Sorry for the late reply, but finally I figured it out what the problem was.
I have a program for translation text (Qtranslate) that was messing out with the shortcuts of Archicad.
 Thank you all anyway.
Go to post
10 Replies 10
DGSketcher
Legend
Perhaps you could share a screen grab of your "Custom Composite Wall" settings?
AGaspar
I´m using the wall layers that come standard with Archicad. It´s Archicad 25 SWE (Swidish)
Are you actually selecting the wall and then copying.it or are you placing a marquee and then copying?
AGaspar
I tried both with the same result.
DGSketcher
Legend
I doubt this is the case but are you sure you aren't pasting to a Worksheet view? There are a limited number of reasons for AC to explode a 3D element.
Is this HELP LINK relevant?
Is it just that one composite that is a problem or any YOU create?
AGaspar
No, It´s between Plans. And some times it´s quite random.
If I copy/past to a new file it can work for a while and then it appends again.
DGSketcher
Legend
Has the composite been brought in from an earlier version of AC?
Have you run "Open & Repair"?
AGaspar
Thanks to inform us you could solve it yourself but it will be better if you help others finding the solution fast if you accepted your reply as a solution, thx a lot.
AC 29 INT 4006/WIN 11
