Myrha18
Copying a selection from a floor plan to others
I wondered if it was possible to copy a selection of elements from a floor plan to others floor plans in one click, and not by copying/pasting to every other floor plan distinctly.
I know that I can copy all the beams (for example) from a plan to others, but is there something similar to copy some of the beams ?
Thank you very much.
2 Solutions
Marc H
The Find and Select tool is fairly powerful in selection criteria (and those may also be saved for future use).  Then it’s easier to copy and paste onto other floors.
Some of the other tools (e.g., Grid) may also help you populate some frame elements at the design outset.  Of course, these tools may not account for typical size reductions (i.e., for seismic) as you move up.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Go to post
DGSketcher
Legend
If your upper storeys are equally spaced then have a look at the Multiply Tool and the Elevate option. It is located under the menu Edit > Move > Multiply
Go to post
3 Replies 3
Marc H
DGSketcher
Legend
Myrha18
thank you very much.
