We value your input!
Core only in composite
Is there a way to create a model view option, or something similar, that will make it so the wall composite only shows the core? I'm exporting our plans to .dwg but our structural engineer doesn't want to show the finishes of our wall composites. Is there a way to make this occur in the export?
Bill
The Partial Structure Display setting is a General Setting for a saved view... change it from "Entire Model" to "Core Only."
Bill
Bill Szustak RA
Principal, Springboard Design
ArchiCAD 25, macOS Ventura 13.4.1
Perfect! Thank you. I knew there was a way and I was overlooking it.
