Corner Wall Intersection Issue
Rene Pahlavan
Hello--
Not sure why this is happening at the corner with the outermost skin of the composite wall not cleaning up - see attached screenshot. Walls are the same composite. Can someone tell me what I am doing wrong or propose a solution for it?
AC27 (Apple Silicon)
macOS Sequoia 15.1.1.
MBP M3 Max (16-inch 2023)
runxel
Hero
Don't disable end lines in your composite.
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
runxel
Hero
Rene Pahlavan
Thanks runxel - it was unchecked.
