Showing results forย
Search instead forย
Did you mean:ย
Search instead forย
Did you mean:ย
Corner Windows
I need a corner window that's 4'x10' (each side) with a transom bar and a grille.
I'm not so concerned about the specifics, but I can't make the corner window "tool" behave.
I click the tool, go into settings, set up a window (either the one I described above, which returns error messages, or an empty one), click on the wall near the corner, and get one window where I click. I go to the settings, turn on the "corner window" function, exit the settings, and the window still does not turn the corner or mirror.
Am I out of luck with the unsatisfactory tool? (I did read the survey thread regarding corner windows, but am not sure I can work with the German function) Or does someone have a corner window they'd like to share?
Thanks...
0 Replies 0
