Cover Fill
Brett Brown
Hi all, Under the "Floor Plan and Section" of a slab, ticking the "cover fill" option, where's the "show area text" hiding?
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
7 REPLIES 7
Brett
I think you'll find "show area text" is only part of the fill tool, not when a cover fill is used associated with a slab / roof etc. (unless it's been changed in AC11, haven't looked there yet)
Erika Epstein
Great idea, though!
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Brett Brown
Yes, Lets hope a little improvement like this is implemented in the near future
TomWaltz
I'm curious.... what's the situation where you're using this? To get an building area or something?
Tom Waltz
Brett Brown
Yes,all sorts of uses,paving slab area's,driveways etc. Where ever you use the "show area text" of a fill. I would have thought being a fill it would have the "show area text" facility like all other fills. Saves time not having to draw fills for area.
I agree that it would be nice to show the areas. Yet while it takes some time, just using the Spacebar (Magic Wand) with the fill tool on the slab perimeter will create a "quick" matching Fill. It is not linked though, so modifications to the slab will also have to be performed on the fill for the area to stay correct.
Erika Epstein
As discussed recently on the forum, select the items you want the area of and go to the Element Information palette where you can get area, volume thick etc.
You might also make a schedule for such items. Useful if you need to check the areas, volumes etc., want to include the info in your drawings, of check against bid quantities...
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
