2007-07-23
05:03 AM
2023-05-25
05:55 PM
Rubia Torres
2007-07-23 07:27 AM
2007-07-24 06:38 AM
Brett wrote:Great idea, though!
Hi all, Under the "Floor Plan and Section" of a slab, ticking the "cover fill" option, where's the "show area text" hiding?
2007-07-24 06:46 AM
2007-07-24 11:27 AM
2007-07-24 12:06 PM
2007-07-24 09:16 PM
Brett wrote:I agree that it would be nice to show the areas. Yet while it takes some time, just using the Spacebar (Magic Wand) with the fill tool on the slab perimeter will create a "quick" matching Fill. It is not linked though, so modifications to the slab will also have to be performed on the fill for the area to stay correct.
Saves time not having to draw fills for area.
2007-07-25 02:18 AM
Brett wrote:As discussed recently on the forum, select the items you want the area of and go to the Element Information palette where you can get area, volume thick etc.
Yes,all sorts of uses,paving slab area's,driveways etc. Where ever you use the "show area text" of a fill. I would have thought being a fill it would have the "show area text" facility like all other fills. Saves time not having to draw fills for area.
