‎2021-06-18
02:51 AM
‎2023-05-24
07:19 PM
Rubia Torres
Solved! Go to Solution.
‎2021-06-18 06:10 AM
‎2021-06-18 10:27 AM
Barry wrote:
If you have the shape of the two ends, then a ruled shell with detailed construction method and a 0 (zero) thickness will give you the joining sides.
It will be a hollow shell but you could always convert it to a morph ans make it solid.
‎2021-06-18 11:18 AM
‎2021-06-29 02:22 AM
Braza wrote:
Another option, is to Select both Morphs > Right Click > Boolean Operations > Union.
Now both of your Morphs are part of a single geometry. Then you can draw custom edges between nodes by: Click one node of the Morph > Select the Pencil button > Draw your edge. Repeat as needed.
When you draw the last edge, you will see that the solid will be closed. Finally check the solidity by Selecting the Morph > Right Click > Check Solidity.
Hope this helps.
