Create composite error
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2012-05-09
06:19 PM
‎2023-05-26
02:27 PM
Rubia Torres
This causes issues as you then cannot see the preview properly and have to the guess at things.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-05-10 03:41 AM
It is best to add this info to the signature in your profile (link at the top of the screen).
Then the info will be there in every post you make.
Do you have the latest hotfix installed?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-05-10 10:49 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-05-11 02:03 AM
Is that the actual screen capture or have you added the fat pink, red and orange lines in photoshop for effect? My composite preview window does not show true line weight no matter what my on screen option is set to.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-05-11 09:14 AM
"s2art" wrote:
Is that the actual screen capture or have you added the fat pink, red and orange lines in photoshop for effect? .
That is an actual screen grab. More worryingly if I open other files the preview appears differently. Unfortunately, the file that the screen grab is from is a company standard template that has had alot of hours trying to get just right.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-05-11 01:36 PM
s2art wrote:My Composite Structures preview always shows True Line Weight regardless of the TLW setting. The line weights in tlodge's example are extremely wide, I would guess around 15 point (5.3 mm) for the middle red line.
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-05-11 01:41 PM
The line weight of the middle red line as shown in the image is 0.18mm, pink is 0.25mm and overall composite tickness is 27.5mm. Weights of line are the same no matter what line weight is given, overall composite thickness is or seemingly any other setting I can think of.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-05-11 01:55 PM
Then I don't know where the problem is. The only way I can get something like your screen shot is with very wide line widths. What you show looks like a bug with your system or file.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-05-13 10:57 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-05-15 07:53 PM
I would try to upgrade to the latest drivers to see if that helps any.
