Create independent details
In an ongoing project, I have created 10 Independent Details. When I start creating the 11th detail, the program refuses to SAVE the contents of this particular Detail.(Everything I did in lines disappeared after I shut down and open the main file) Only the dimension info would show. I checked all layers are on.
I tried making changes to all files previous to the new 11th file, it would
save normally.
I also tried creating the 12th detail with lines, circles, fills etc. After SAVE, shutdown and reopen, only the circles are saved.
I tried opening another project file, and it works normally.
Has anybody experience this glitch?
13 Replies 13
TomWaltz
Wow, that's a new one.... and a bad one!!
What build of Archicad are you using? If you click "About Archicad" in your Navigator it will tell you. (Under Help > About in the Navigator, set to Projetc Map)
Tom Waltz
I am using 2045 USA full .
TomWaltz
I'm not sure if it's related, but the next update to build 2172 is availble.
Tom Waltz
Benjamin,
One of my clients experienced the exact same behavior. So, I feel your pain. All of her work on an independent detail was lost - and only the dimensions remained. I reported this a couple of days ago and am waiting to hear what GS has come up with.
I was able to get her file to work again for me using the fix-corruption-via-PLA method. Oddly, the same method did not work for her!
Try this:
Save your project as a PLA. Close AC. Start AC and open the PLA, let it read the library parts from the PLA itself. Save as PLN and exit AC. Start AC again, open the 'new' PLN and in Lib Mgr point back to the original libraries. Draw in the detail window, save, re-open and see if the problem is gone. (I don't know if all of the extra close/open AC steps are necessary, but that seems to be the only difference between what worked for me and didn't work for her.)
Thomas Holm
Sounds reasonable. Quitting the program clears all the caches. Not quitting may not clear enough bad data.
Seiss Wagner
Sounds scary to me, like everyone, I have a lot of independent details in my drawing sets. I find it one of the most useful tools in the ArchiCAD pallette.
Benjamin are you a MAC or DOS user?
Carl was your client using 2045 or 2172. MAC or DOS?
ArchiCad 21 / OS X 10.13.5 /
iMac 3.2GHz i5 - 32GB /AMD Radeon R9 M390 - 2048 MB/
Dual 5K - 27" Displays
I am on MAC G5.
I still haven't solved this problem. I also have lots of Details in all my project files. I am crossing my fingers none of the data have been lost.
awhile ago...someone issued a fix to corrupted elevations...I wonder if that would work...I have been looking for that fix...can someone help...I know it had something to do with rebuild all of the elevations at one shot...maybe it would work for this.....
GS Tech Support has provided the resolution to this problem.
It looks like the result of a Home Zoom bug that was identified in a past build (and has since been corrected). The remnants of the bug may still linger on in some project settings.
The detail that was problematic was located several miles away from the origin. Most likely your client did not purposely put it there. What happened was your client never ever set the Home Zoom. (I don't use it and many users don't.) Over time, due to the old bug this zoom setting became absurdly small. The user, unaware that the detail was being placed a bazzillion miles from the orgin, went on his/her merry way not realizing that Archicad was preparing to delete the lines.
Archicad removes objects that are beyond what Archicad considers internally acceptable for details. Unfortunately the local origin of the detail gives no clue to the user of the situation. To verify the problem double click on the user origin button to show the global origin values
The solution is New and Reset for new projects or just make sure that the Home Zoom is set to something reasonable. With the current build [2172] this value should not change on its own.
