Ted Taylor
Creating Custom Door Panel
There is an option in a number of the door objects to create custom door panels. I could not find anything in the online help on how to make this work.
I tried the following:
Created door panel with odd shaped hole in it using slab tool in plan window.
Saved it as library object in 3d window - saved it to the door macro folder.
reloaded library.
inserted name of panel in appropriate spot in door dialog box.
The door has a panel but there is no hole in the panel.
Can some one point to where the procedure is given or explain the procedure.
Thanks,
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
13 Replies 13
Link
Whether it's a bug or not, I think you have to save your custom component into the loaded ArchiCAD Library. I don't think it will appear as an available component if saved anywhere else.
Link.
Dennis Lee
For me, as long as I save as "Custom Component", I can save it in my project library or office library - and it works beautifully. I don't even have to reload any library. Also, the name of the custom panel will be in a drop down list to choose from. I don't have to type them in.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
Dennis wrote:
My Custom panel field was seemingly 'locked' - and I was struggling with this issue, until I read the pdf guide for AC10 US library doors that I downloaded sometime ago somewhere.
In short, you have to save as "Custom Component", and not an "Object".
Thx Dennis Lee for reading my one month old post.
Yeah , that's right ! It works!
Dennis Lee
No problem at all! I was struggling w/ the same thing - and i know how difficult it can be, so I was happy to share what I found.
Windows 10 x64
Since ArchiCAD 9
