2011-10-12 12:07 AM
2011-10-12 02:51 AM
2011-10-12 03:01 AM
Robert wrote:I would say a module is a bit more like an XREF - in fact you can use XREFs in Archicad just like you can in Autocad (or so I have been told).
As I understand the module is the equivalent of Autocad's block.
Robert wrote:Make sure that your grouping is "Enabled" and not "Suspended".
However it doesn't seem to function the same. After placing the module I can move it rotate etc. but once it is released it doesn't function as a group of entities. What's worse is that if you perform additional work in the drawing you cannot delete this block. You can undo back and remove it but that's not practical. Am I missing something here????
2011-10-12 02:44 PM
