Learn more
Creating a brick string
Hello everyone, I was wondering if someone could help with an issue I'm having. I'm creating a brick string such as in this image: http://forterra.co.uk/inspiration-gallery-detail/208/hereward-light-london-brick-project .
I have set up walls already and so was hoping to create the different colour bricks overlayed like a 'sleeve' which I can easily move up, down, change colour etc. I understand it may be possible with a complex profile but where I've started working doesn't have those and as I'm pressed for time they won't want me playing with complex profiles as it's taking enough time as is...
I created a wall type 1mm thick so I could just trace the edge and set the height / material as needed. However the brick extends past the intersections at corners. I was wondering if there's an option I'm missing, or if there's simply a better way, I'm sure you experienced professionals could help me.
Thank you for your time.
3 Replies 3
David Maudlin
yellowbear:
You have a couple options:
1. Put the strip walls on a layer with a different Layer Intersection Group number.
2. Adjust the strip walls so their Reference Lines are in a different location than the main wall reference lines. I think this issue is caused by the two walls' reference lines being in the same location, so ArchiCAD is trying to figure out how they should intersect.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
DGSketcher
Legend
I had a similar project. Complex walls is probably the best solution if you have several walls the same, but the quick work around I used was to create 100/102mm wide beams with a material strength greater than the general brick and place them in the wall. This would be more suited if the strings aren't continuous e.g. brick sills or feature courses in limited locations. Using a beam should also avoid AC trying to resolve wall intersections.
Let us know how you get on so others can learn from your experience.
Firstly, thank you both for your quick replies, incredibly helpful and will take on board for the future:
I can confirm that on a separate layer with a different junction order has done the trick - my walls are at 8, and I've used 10 for the brick string course and all is well.
I will keep the beam trick in mind as well, in case I can apply to other situations.
Thanks guys!
