Creating a smooth terrain from terrain skirts automatically
Ultratimsil
i have created a terrain out of lines i took from a reference, the lines had multiple nods, and when i finished it create a stair like terrain and not smooth, so i have been doing it manually.
as you can see in the picture the left side is what i did manually and on the right you can see the stair like terrain that i will be working on. is there a better method or an initiall approach i should take to avoid this amount of manual work?
undefined
Marc H
It doesn’t look like you are using the Mesh tool?  With that, you can overlay Splines from your survey over the mesh and, with the magic wand, embed nodes into your mesh and elevate them in groups.  There are a few helpful videos on this process.  It will produce a very smooth terrain.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Marc H
I think that's the way, i should have done it from the beginning.
Thanks
Setup info provided by author
