2018-01-07
10:56 PM
2023-05-24
08:25 AM
Rubia Torres
2018-01-08 01:43 AM
2018-01-08 09:41 PM
2018-01-09 02:00 AM
2018-01-09 04:37 PM
2018-01-09 10:39 PM
2018-01-10 12:55 AM
2018-01-10 02:19 AM
DrWho wrote:It is pretty simple.
Thanks for the assistance Barry in understanding how trimming with an SEO is different than with a roof. I actually tried to do that but got frustrated as the SEO tool allowed me to pick the wall to be trimmed it never gave me a chance to create the cutting shape. It only seemed to want me to provide the cutting shape based on the shape of another object which I would have had to create. I tried to find a step by step tutorial (written or video) to allow me to understand the SEO tool better but I couldn't seem to find anything using the search box on the website. Do you know of any links?
2018-01-10 10:35 PM
2018-01-11 01:43 AM
DrWho wrote:If existing elements are not suitable for the operation then feel free to add other elements that can be placed in a hidden layer that can be the exact shape for what you want to trim to.
In my case I have a section of seating and it takes a couple of stairs to go from one level to the next. I used the stair tool create those steps which means there is a space between the bottom of the steps and the seating walls and floors. If I use the seating structure to trim the wall the result does not fill in under the steps. Worked but not as well as I would have liked. It would be better if the user could modify the operator elements (that is change the shape) as that would make sure the trim is exactly what the user wants.
DrWho wrote:Yes SEO only happens when the elements intersect.
I did notice what I think is a drawback to the SEO tool. I noticed that the "execute" function only works when the operator actually crosses into the item to be trimmed. If the operator abuts or does not intersect the target the operation will fail. Obviously the tool does not "Project" the features/shape of the operator onto the target but if it did then it would make some of the work go quicker and easier. Maybe one of the GS programmers could look at adding these capabilities.
