‎2018-01-07
10:56 PM
‎2023-05-24
08:25 AM
Rubia Torres
‎2018-01-11 04:19 AM
I did notice what I think is a drawback to the SEO tool. I noticed that the "execute" function only works when the operator actually crosses into the item to be trimmed. If the operator abuts or does not intersect the target the operation will fail.The operator itself doesn't need to intersect, just the zone of the operation type selected given the extruded up/down options. If neither the zone nor the operator itself intersect, you just won't see the effect of the operation, but it's still there.
Obviously the tool does not "Project" the features/shape of the operator onto the target but if it did then it would make some of the work go quicker and easier. Maybe one of the GS programmers could look at adding these capabilities.What do you mean by this? Using the subtraction with upward/downward extrusion, you'll get a vertical hole that follows the cross section of your operator. If you're wanting the entire shape (solid) of your operator intersecting it's relevant parts is the only way.
‎2018-01-11 04:54 AM
Lingwisyer wrote:Yes sorry I wasn't 100% clear.
‎2018-01-11 10:39 PM
‎2018-01-12 03:54 AM
‎2018-01-18 07:28 PM
‎2018-01-19 02:31 AM
DrWho wrote:I would love to but unfortunately I only have the same contact with the GS guys/gals that you do.
Maybe you could pass that idea on to the GS guys/gals to see if it might be added.
DrWho wrote:Glad to here it.
Anyway, got my problem solved for now.
‎2018-02-06 07:18 PM
‎2018-02-06 07:26 PM
‎2018-02-07 02:21 AM
‎2018-02-07 08:00 AM
