2016-02-1407:35 PM - last edited on 2023-05-2408:42 AM by Rubia Torres
Cursor does not select wall corners when drawing zones
2016-02-1407:35 PM
I have been drawing zones inside rooms and everything functioned as it should. However, I wonder if I may have inadvertently changed a setting because the cursor "suddenly" no longer selects room corners. There is now a small grey dot slightly removed from the cursor and the zone is drawn from this grey dot, not from the end point of the cursor. What did I do?
