‎2025-08-05 09:37 AM
Hi all,
Is there some way to rotate the reference line of planar curtain walls? X/Y to Y/X
I am sure I have done if before you align with skewed buildings...
Ling.
‎2025-08-06 05:52 AM
You can rotate planar CW to an angle up from xy plane in 3D view, please see attached (if that was what you wanted to achieve).
‎2025-08-06 08:12 AM
I am wanting a rotation around the z-axis, x/y to y/x. I ended up just rotating the entire curtain "wall" and redefining the boundaries...
‎2025-08-06 08:27 AM
Is it as simple as manually swapping the scheme column and row sizes with each other?
That works for a simple grid.
‎2025-08-06 11:15 AM
There are multiple instances using the same pattern, so it is easier to manage if they are consistent.
